EK Swaps 1996-2000 Civics
What type of clutch and flywheel would you recommend for a y7/y8 swap
Old Jun 18, 2010 | 10:50 AM
graymonkey44's Avatar
Default What type of clutch and flywheel would you recommend for a y7/y8 swap
I did a y8 swap on my 1999 civic lx and since then i've been reving the **** out of it and hitting the higher rpms. Now my throw out bearing needs to get replace and I'm thinking of just getting a whole new clutch.
No because of the higher horsepower from the swap should I go with a stage 1 or just OEM? Also should I just keep the flywheel or go with a lightweight one?
I will do mostly daily driving and want to know what a good weight for the flywheel would be.
Old Jun 18, 2010 | 01:15 PM
Keep stock weight flywheel. The lightweight flywheels cause the engine to rev quicker but at the same time cause the revs to drop quicker. The
Also, you are supposed to resurface it when you replace the clutch, but Advance Auto Parts sells Perfection OEM-spec flywheels for only $60 so I would go with that (also look in their newspaper-ad for __%-off coupons).
If you like spirited driving I would get a stage 1 clutch. OEM will handle the power of the stock engine and then some just fine but stage 1 clutch will grab faster... should decrease your shift time.
ale19859
Jul 20, 2011 02:58 PM
rocky12345
Sep 6, 2010 04:33 PM
inthezoneac
Apr 12, 2008 03:05 PM
zz5
Dec 19, 2006 10:51 PM
Hot94vtec
Aug 17, 2006 03:16 PM
