98 civic d16y8
ok heres the deal i blew the motor in my crx and im looki9ng at buying this 98 civic... looks good an all but i dont kno anything about the d16y8.. so my question is, is the motor a good one and what kind of specs for hp am i looking at... the guy is wanting $3500 for it it has 145k sounds like he is kinda old but the car is in perfect shape.. im used to working on 92-95 gen cars even my crx has a d15b7 out of a 92 how much diff is there between these year?
Wikipedia is your friend
"D16Y8 - VTEC * Found in
o 1996-2000 Honda Civic EX (US)
o 1996-2000 Honda Civic SI (Canada Only)
o 1996-1997 Honda del Sol Si
+ Displacement : 1590cc
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Rod Length : 137 MM
+ Rod/Stroke : 1.52
+ Compression : 9.6:1
+ Valvetrain : SOHC 4 valves per cylinder
+ Power : 127 hp (94.7 kW, 229 ps) @ rpm
+ Torque : 111 ft·lbf (45.79 kg/m, 145.1 Nm) @ rp
+ Head Code : P2J
+ Piston Code : P2P
+ Redline 6900 rpm
+ ECU Code : P2P"
It's a common motor, really nothing to get excited about (unless built!). 98 Civic EX, stock everything, 145k miles, perfect body (no dents, scratches or anything) is definitely worth at least $3000. I would just make sure that the timing belt/water pump was done. They usually need replacing at 95K or so.
What color is the car you are looking at? 5 speed?
+ Rod/Stroke : 1.52
+ Head Code : P2J
+ Piston Code : P2P
+ Redline 6900 rpm
+ ECU Code : P2P"
yea its perfect im gunna go look closer at it and drive it around 730ish... its white with 17inch black rimswindows blacked out but has a gay triabol decal on the sides but o well they prolly come off.... doesnt even have exhaust plain civic with rims tail lights and decal idk...ty for the info and it is a 5 speed
mgm940428
12
Dec 14, 2005 04:46 PM
JDMracer00
Aug 30, 2005 12:04 PM
roguecivic97
Jan 13, 2005 03:38 PM
