d15b7
so my timing jumped and im asuming the valve hitt he pistons and i have a few bent valves... first question is with he head off how do i check each valve to see if they are bent or not.... how easy is it to take the valve out and put new ones in and what else need to come aprt on the head to do this? any tips would be very helpfull..
i found a whole new used head in minnesota that all it needs is to be resurfaced............only 75$ for it...... when i go to put this back together i make sure the head is at TDC and i can put the crank at TDC with the head being off right?
Correct. Good luck with the fix.
