b16 into 90 hatch
Old Dec 12, 2007 | 10:42 AM
cant_beat_VTEC's Avatar
Default b16 into 90 hatch
hey whats up, i just bought a90 hatchwith a blown motor.... so ya im pretty sure i want to go with a b16 but what all do i need ? i looked at one online and it comes with motor, tranny, ecu, all brackets and sensors, and all reguired cables ....so what else am i gonna need? HELP!!![]
Old Dec 12, 2007 | 12:20 PM
Mr Mobsta Man's Avatar
Default RE: b16 into del sol
Mounts, shift linkage,and engine harness (unless you meant harnesses when you said cables). It is also a good idea to replace the water pump, timing belt, and alternator while the engine is out because you don't know what condition they are in and it is easy to swap them when it isn't installed.
Old Dec 12, 2007 | 01:11 PM
Pete's Avatar
Get a gsr instead, that del sol would MOVE!
Old Dec 12, 2007 | 05:52 PM
it comes with a wiring harness but its out of a 88-91 honda so wouldnt it bolt up to my hatch and what about axles
Old Dec 12, 2007 | 05:56 PM
You need thewiring harness and ecu for the engine you are swaping in. Yes you need the axels from the car the engine came out of.
Old Dec 12, 2007 | 06:20 PM
Default RE: b16 into 90 hatch
k thanks im buying everything for 1500 without the axles is that cheap for a b16 oryou think i can get cheaper
Old Dec 13, 2007 | 07:08 AM
blackmassacrer's Avatar
sounds like an alright price
http://hmotorsonline.com/shop/sc2000...USDM%20Engines
Old Dec 14, 2007 | 02:35 PM
you would also have to convert your 1990 hatchback dual point to mpfi assuming the fact that u dont have a si or ex.
ecu,wiring harness,complete motor,transmission,axles,motor mounts,front rotors,shift linkage.
mcwilly905
Jun 18, 2009 08:58 AM
littledog
Jan 15, 2008 05:30 AM
carter
Jul 18, 2007 08:42 PM
S.aelee I.nside
Mar 27, 2006 11:54 AM
jwsimons
Jan 7, 2006 12:40 PM
