B16A2 @ 10.000rpm
ok here is the deal
i am getting a vti eg soon and i was thinking about some plug a play mods to get around 200ps (n/a )with no problems, and i want to increace the rev limiter to 9.800 -10.000 rpm
i was thinking about JE high compr pistons or shave the head a few mm for higher compression, harder valve springs, b18 cams,b18throttle body,dyno and chip the ecu.and a fidanza aluminum flywheel or shave and lighten the stock one, and perhaps an aftermarket oil pump and water pump.i dont want to spend a hugh amount of money but what else do i did to get to that goal ihaveset?do i have to do any mods to the crankshaft to get the engine to rev that high?
i think i will be around 200ps and 19kg of torque with that set up.
200 whp is nowhere near impossible. I even have a dvd showing you how to build a 200whp N/A b16. Go to hondatech and lookup omnimans dvd adn he did it with all OEM internals pretty much. I could see a 220whp b16 bein within reach.
^^^ PLEASE show me! Links? And I dont wanna see some sleeved 2.0 litre "b16" I searched on hondatech for the last 2 days trying to find info on NA b16s and no one showed anything more then 180hp.
Also, find a reason instead of saying "um...no"
