the best block?
Old Jul 31, 2006 | 11:29 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default the best block?
what is the best block to get 200 hp out of a b16a2 head. I wasnt sure if its the b18c1, b18c5 or b18b, i remember someone saying that you can get 200 hp out of a b block with a b16a2 head. i will be doing forced induction as well. thanks for the help
Old Jul 31, 2006 | 12:21 PM
pWnEdU's Avatar
Default RE: the best block?
b18c5 comes stock with 200hp.
Old Jul 31, 2006 | 04:38 PM
ef4life's Avatar
any block is capable of 200 hp. the c5 has 195hp stock and is a very good engine, but costs a ton. a gsr would be the way to go 170 stock and more torque than a b16, still expensive. a turbo d could get you at least 200 hp on a stock bottom with a good tune.
Old Jul 31, 2006 | 04:41 PM
there is a b series combo with the b16a2 head that gives a good hp with a different block
i just dont know what it is
Old Jul 31, 2006 | 04:51 PM
ef4life's Avatar
any b16 head with a b18 or b20 block can make 200 hp is you build it right
Old Aug 1, 2006 | 05:18 PM
riceburner700's Avatar
got a really good point^^^
Old Aug 1, 2006 | 09:16 PM
burnindesirez02's Avatar
I know of a Block specifically for hondas that put out 270 hp and for 7k
Old Aug 1, 2006 | 09:17 PM
im lookin to swap out my b16a2 block and put a better one in for the b16a2 head, this is why im asking
Old Aug 1, 2006 | 09:18 PM
sacicons's Avatar
ORIGINAL: burnindesirez02
I could build one for way less than that. is that the Dart block you are referring to?
Old Aug 6, 2006 | 12:23 PM
MY99SI's Avatar
i would go with the CRVtec setup then throw in a set of ARP rod bolts and u can boost it and make more than 200 hp all day
