Best Engine For F.I.
Old Nov 11, 2006 | 12:15 AM
ProjectGSR's Avatar
Default Best Engine For F.I.
I'm sure this question has been gone over but I didnt find any search results...
Best engine or set-up for F.I. ?? I heard something about a b20 block and b16b head or something? Than theres another B engine with low comp that people love for boost. Anyway, your info is appreciated.
Old Nov 11, 2006 | 12:21 AM
Pete's Avatar
Default RE: Best Engine For F.I.
The best stock engine for FI is goin to be the one with the lowest compression..........all honda engines are great for boost considering a good tune/forged internals or both.
Old Nov 11, 2006 | 09:42 AM
ORIGINAL: ProjectH
a built one...
As far as stock motors, the one that tends to make the most power is the LS block with a b16 head. But from what I hear, it's an absolute bitch to tune correctly
Old Nov 11, 2006 | 09:48 AM
drbyers's Avatar
you're gonna have to reinforce just about any engine you use with a turbo unless it has low boost.
use the b-series and save some dough...
Old Nov 11, 2006 | 10:02 AM
Marty's Avatar
K series are running up around 500 to 530whp on stock blocks
Old Nov 11, 2006 | 10:03 AM
Kedawei's Avatar
Depends on your power goal. If you need more than 500, B18C1 or H22 is best imo. Anything below that I'd use a D.
Old Nov 11, 2006 | 05:40 PM
Nail I3unny's Avatar
i wouldnt go with the D unless you are staying below 300-350 hp.
Old Nov 11, 2006 | 06:09 PM
Cody_Bell97's Avatar
from what i here if u going with a obd1 ecu wich ive learned is the best to mod the b18a1 wich is the ls engine or the zc engine are the 2 best for turbo bc of the compression also the h23a wich is the honda prelude si engine. also i have heard is better to turbo a non v tech engine for what ever reason im not sure but that just what ive heard these are all non v tech engines and all low compression so they are good ones to use.
hope i could help
Old Nov 11, 2006 | 08:35 PM
Kedawei's Avatar
ORIGINAL: Nail I3unny
Explain your logic here.
Old Nov 12, 2006 | 12:02 AM
TheMoogly's Avatar
ORIGINAL: Marty
That would be nuts... for that much power do you have any idea of a $$$ amount for that kind of build?
