the best synthetic oil ???????????????
Fram filters are garbage no matter which way you use them. There's a reason they're like 2 dollars a piece. Cut one open and you'll quickly see why a lot of people stay away from them. They're mostly cardboard and they're made very very cheaply. Also, they have a real tendency to make the gasket stick to the oil filter mounting boss, and I've actually seeing them cause CEL's for low oil pressure.
http://www.amsoil.com
click on the car and light truck link on the right and you can order anything you need for your car.
amsoil is the best.
amsoil is the best.
Been using Mobil 1 with the Mobil 1 filter for the past 70K in my '95 Civic, D15B7. I change the filter every 6K, top the oil off, then drain the oil + fresh filter every 12K. At 189K, runs perfectly, cams still look brand new, no smoke and doesn't burn oil. Also have K&N cone filter on a cold air intake pipe. Clean & re-oil it once a year.
Nice move. I think royal purple is one of the best brands out there. On a show called horsepower (on spike) they did a test between royal purple and some other top brand (i forgot, sorry) and royal purple gave you like 10-15 more HP!!
TowerXVI
Jul 16, 2014 01:20 PM
oilltd
Jun 10, 2008 04:06 PM
oilltd
South West
Jun 10, 2008 03:07 PM
Vadagar
May 26, 2006 12:51 PM
