block guard
Old Apr 16, 2007 | 10:32 AM
Fiasco's Avatar
Default block guard
Anyone have any experience with these? Im building to about 275 whp, which isnt off the page, but i figure the more stability the better.
http://cgi.ebay.com/ebaymotors/KMS-B...spagenameZWDVW
Old Apr 16, 2007 | 10:43 AM
riceburner700's Avatar
Default RE: block guard
not nessisary, just get a nice hone or .020 overbore and your sleeves will handle that just fine. if you want a block gaurd some people say good and some say bad. i just think they cause hotspots at the top of the cylinder from lack of cooling
Old Apr 16, 2007 | 11:24 AM
Fiasco's Avatar
thank you sir
Old Apr 16, 2007 | 12:24 PM
Remmy's Avatar
Ive got a block gaurd. Its a nice alternative to sleeving. I think for the money, it is very worth it.
Old Apr 16, 2007 | 01:27 PM
MY99SI's Avatar
ive heard of hotspots occuring with a block guard but like riceburner700 said, a .20 over bore with a block guard works good.
i built a b16a with .20 over JE SRP pistons on Eagle rods and a mild ported GSR head and at 20 psi it loves it, alot more torque over a standard b16. we're goin to run it up to about 25-30 psi on a SC 60-1 in a 92 civic hatch. should be pretty righteous. and another car around here's doin pretty much the same setup. i'll make a video if you want to, there's one on street fire that i made and in the vid both cars had less mods then now. so it'll be cool when i come out with a part 2 version of my first vid.
Old Apr 16, 2007 | 03:15 PM
Kedawei's Avatar
Block guards do make hot spots in the cylinder where coolant can't reach, which even if you can't hear it, increases detonation. Over time this leads to cylinder wall failure, actually accelerating the wear that they are advertised to retard.
Sleeve it or leave it stock.
joeunit96
Mar 8, 2011 10:59 PM
tombakers
May 4, 2008 05:23 AM
copyguy6188
Mar 19, 2008 07:54 PM
4doorturbo
Aug 27, 2006 10:25 PM
smokingemcee
Jan 24, 2006 11:32 PM
