building bottom y8
Old Dec 28, 2006 | 09:07 AM
stylincompact's Avatar
Default building bottom y8
hey guys just need some assurance. im building my bottom end for turbo..i have vitara pistons and eagle h-beam rods. now what bearings do i need, says color coded where is that and do i need to do anything before i instal the pistons and rods..im not boring and the walls are great.help
Old Dec 28, 2006 | 09:27 AM
Marty's Avatar
Default RE: building bottom y8
what berrings? I like clevite
Old Dec 28, 2006 | 10:03 AM
While you're in there you should pull out the oil pump and bore the ports to clean up that bottom end oiling issue.
Old Dec 28, 2006 | 06:15 PM
what oil issue. and im using honda bearings
Old Dec 29, 2006 | 06:39 AM
ORIGINAL: stylincompact
the y8 has bottom end oiling issues due to a not so efficient oil pump setup. It'd be sad to see all those nice new parts go to hell because they're not getting enough oil.
Old Dec 29, 2006 | 07:31 AM
ok ill do that anyting else? do i lube the piston rod bolt or just tap it together?
Old Dec 29, 2006 | 08:13 AM
You'll want to take the oil pump out, and bore it's ports so that you get more flow through them. It doesn't take much, a little bit goes a long way.
Are you planning on running a y8 head too?
Old Dec 29, 2006 | 01:22 PM
yeah i have a y8 head. thats all set
Old Dec 29, 2006 | 02:01 PM
Might want to consider moving to a z6 head, it's a little easier to tune, and you can squeezea few more reliable ponies out of it. Just a thought
se7ensectoolate
Oct 24, 2005 02:19 PM
ldk_honda
Oct 10, 2005 04:31 PM
turbob18c1
Oct 10, 2005 08:07 AM
civic96RB
Sep 24, 2005 10:42 PM
Super Mario
Nov 12, 2004 08:59 PM
