Cam Gear, Lightweight Pulleys
Old Dec 29, 2008 | 08:23 PM
4DoorSedanMan's Avatar
Default Cam Gear, Lightweight Pulleys
I got a 92 Civic LX Sedan with the factory 1.5L D15B7. I was thinking about upgrading the timing and the gearing but I didn't wanna rip the motor apart. I wanted to do the Unorthodox Racing (Ultra-T) Adjustable Cam Gear, and I also wanted to do the Unorthodox Racing (Ultra-SS) Over-Drive Lightweight Power Steering, Alternator Pulleys, with the Unorthodox Racing Under-Drive Crankshaft Pulley. What do you guys think about this?
Old Dec 29, 2008 | 08:27 PM
ej6buddy's Avatar
How built is your motor??? I thought so, it's probably stock. You don't want to change any pulleys or cam gears when you have a stock motor. If you want more power, go for basic bolt ons.
Old Dec 29, 2008 | 08:33 PM
Well, not to long ago, I installed an AEM Cold Air Intake System, DC Sports 4-1 One Piece Ceramic Header, Magnaflow Direct Fit High Flow Race Cat, And A Full Magnaflow Cat-Back Exhaust. I was just curious as to what kind of HP/TQ gains I can gain with a Cam Gear and Lightweight Pulleys. I was also thinkin about havin the Cam Gear adjusted to (+2 Degrees) for a little low-end HP & TQ.
Old Dec 29, 2008 | 09:02 PM
ej6buddy's Avatar
All i'm going to tell you is I wouldn't, as will anyone else that will respond to this thread. Most aftermarket pulleys aren't correctly balanced for high horsepower applications. If you want more power, I will suggest a cam and springs, larger throttle body, and a tune, and maybe a port/polish with port matching. You're not going to gain that much more power from your d series without boost, which would make most of your bolton's useless.
Old Mar 22, 2010 | 08:39 AM
jordanrw260's Avatar
What about if you use the Unorthodox Racing Ultra SSc series which is the same size as stock and does not underdrive anything. It is just lighter in weight. Would this be harmful to the motor?
Old Mar 22, 2010 | 04:52 PM
Lewy2k's Avatar
It wont harm the motor buy wont really help when its stock other than bolt ons. All the stuff you have on the motor probably only gets you 7-10 hp. The cam gear would be pointless unless you upgrade the cam or have milled your head.
Old Mar 22, 2010 | 06:23 PM
I have a 94 del sol with b16a2, I was planning on adding I/H/E, and with the pulley set from unorthodox I was hoping it would add some more power. Does anyone else have these basic add-ons with a similar setup?
Old Jun 13, 2012 | 10:50 AM
hairy5050's Avatar
Can an adj. gear help fuel economy?
Old Jun 13, 2012 | 11:13 AM
No. I seriously doubt fuel consumption will change.
Old Oct 25, 2012 | 08:09 AM
moreMPGs's Avatar
Default lighter cam gear = more MPG ?
Well an aftermarket (aluminum) cam gear is lighter in weight, so technically it should save gas / use less power to get spinning. However, the difference in weight between stock & aftermarket cam gears is kinda negligible I would think.
NewtoCivics
Sep 10, 2011 06:58 AM
scottdh20
Apr 30, 2008 12:29 PM
4doorcivic9
Mar 5, 2007 07:41 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
