car still smokin
i posted once about this car smoking since then i have put new valve seals and springs. the car has got a lot better but still smokes some.
did compression check again its 195-200psi book says should be 185psi. i dont see how the rings can be worn out and comp be that high.
the car is an 89 civic hatch with a d15b6 . anything u think may cause it to smoke let me know.
i put a can of engine restorer in it today i am going to see what that does but i will do a leak down test tommorow.
the smoke is blue so its oil, i put half a can of sea foam before but not lately. i thought maybe the oil rings either it be one or all could be worn or broke leaving the oil on the walls.
if i tear it down re-ring and new bearings i want to put the d16z6 pistons, rods and head in/on the block the z6 head only has 500 miles on it that damn 8 valve motor is slow as crap. this is just my beater car dont want to invest to much $. as far as i know the rods and pistons will just interchange i know the head will and i am not worried about the v-tec working.
if anything here will not work please let me know. thanks for the help so far
D15B6
Found in:
1988-1991 Honda CRX HF
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Compression : 9.1:1
Power : 62 hp(88-89) 70 hp(90-91)@ 4500 & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
D16Z6 VTEC
found in:
1992-1995 Honda Civic EX/Si, Del Sol Si,
Displacement : 1590 cm3
Bore and Stroke : 75 mm X 90 mm
Compression : 9.4:1
Power : 125 hp @ 6600 rpm & 106 ft·lbf @ 5200 rpm
VTEC Switchover 4800 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
now is the stroke difference in the rod or the crankshaft???
NR1236
Nov 18, 2005 01:28 PM
