CEL issues...
Old Feb 16, 2008 | 08:59 AM
Blue Canon's Avatar
Default CEL issues...
So my check engine light has come on again... this time it's a P1399 which is a "Wait to start Lamp" to my knowledge that's a diesel engine thing... Is anyone else having, or heard of that problem? Also I'm goin through oil at an alarming rate.. (burning, not leaking, unfortunately) Any suggestions? Money's tight, is there a "quick cheap fix" (other than a new engine, or a new car all together?)
Old Feb 16, 2008 | 10:47 AM
Default RE: CEL issues...
P1399 is not a CEL code listed in the 96-98 Civic service manual.
See what code is retrieve using this method:
http://www.honda-tech.com/zerothread/1901557
The way your engine is burning oil suggests that an engine replacement may be in order.
Old Feb 16, 2008 | 11:14 AM
Blue Canon's Avatar
I had it scanned at Partsource, it came back with a random misfire, a misfire cyl. 1, misfire cyl. 2, and the P1399.
Old Feb 16, 2008 | 11:49 AM
For the misfire, check whether the plugs are fouled and whether the distributor rotor and cap show signs of wear and corrosion. If plugs are fouled, you also may want to change the plug wires.
Pull the CEL codes with the method described in the link to determine whether the unusual P1399 code is replaced by an interpretable code. Clear the ECU and see whether the same codes reappear. Troubleshoot only those codes that repeat.
Old Feb 16, 2008 | 01:09 PM
Blue Canon's Avatar
cool, thanks, will do.
Nelly
Apr 10, 2007 11:31 PM
turbo y7
Jun 4, 2005 03:06 PM
hxcivicboy
Jun 4, 2005 12:12 AM
b16Ek4
May 25, 2005 08:48 AM
215civic
Apr 20, 2005 10:27 PM
