Civic 1.4 98hp model 1991 needing advice!
Old Jan 6, 2007 | 11:56 AM
vasp's Avatar
Default Civic 1.4 98hp model 1991 needing advice!
hello,
i would like to ask what air filter should a friend of mine buy to make a small upgrade to his civic?He is planning to put a rear mufler upgrade as well,and also thinking of adding a chip.Is this thing worth it?What else should he change,or not change if he wishes to gain a small amount of torgue+power around the area of 3000-5000rpm?
thanks in advance for all options!
Old Jan 6, 2007 | 12:07 PM
riceburner700's Avatar
Default RE: Civic 1.4 98hp model 1991 needing advice!
dont bother with the chip because unless you are running more power than stock you will just waste your money for a couple more horsepower. as for the muffler that you would weld on it will be just for sound, do a full catback if you want some more power and torque. If you are gonna get an aftermarket stock replacement filter k&n is the only way to go
Old Jan 6, 2007 | 12:16 PM
vasp's Avatar
cheers mate!
so you think a full catback + a K/N filter would improve things?
Old Jan 8, 2007 | 10:46 AM
TheShimster91HB's Avatar
Thats your best bet, maybe a 4-2-1 header as well?
Kegrrrrz
Aug 1, 2014 08:40 PM
ASHLEYS99CIVICEX
Jan 8, 2009 09:04 PM
d1nonlyjv43
Aug 19, 2007 09:32 PM
alternative_energy
Mar 2, 2007 01:39 AM
