compression
Old Mar 20, 2006 | 10:19 PM
hondadelsoldrvr's Avatar
Default compression
when you test your compression and it comes back almost perfect, does this meen that the rings should be fine? i am having blow by somewhere and i have narrowed it to valvestem seals or the rings and i am wondering if the compression would be affected by either one of these.
Old Mar 20, 2006 | 10:30 PM
Pete's Avatar
Default RE: compression
Almost perfect compression usually means your engines internals are in good shape. I would say its not the rings, as bad rings wouldnt show next to perfect compresion results.
Old Mar 20, 2006 | 10:36 PM
but yet i have a rebuilt head. so it shouldn't be the valve stem seals should it?
Old Mar 20, 2006 | 10:37 PM
AgentofDarkness's Avatar
How do you know that there is blowby? Its pretty hard for you to have blowby if the piston rings are sealing correctly. You can't have blowby through the valve stem seals b/c blowby gasses are defined as "Oil vapors and other emissions that leak past the piston rings into the crankcase" (modern automotive technology).
chones2083
Jun 2, 2005 06:48 PM
nachoman
May 23, 2005 02:37 PM
aquessada
Feb 21, 2005 03:00 PM
Dickie
Feb 10, 2005 06:24 PM
Blackhatch124
Nov 10, 2004 08:20 PM
