compression
Old Dec 20, 2007 | 10:31 AM
hovo61788's Avatar
Default compression
hi I own a 98 civic ex, i want to do a compression test but i dont know what the difference is between good compression numbers and bad compression numbers. thanks
Old Dec 20, 2007 | 10:37 AM
riceburner700's Avatar
Default RE: compression
if they are all within 10psi of each other they are good, say you have 180, 175, 70,185 cylinder # 3 is really bad with only 70. make sure the engines fully warmed up ,throttle wide open and fuel disconnected
Old Dec 20, 2007 | 10:43 AM
hovo61788's Avatar
ok.but what number range do i want to look for? im guessing 70 isnt good.
Old Dec 20, 2007 | 11:50 AM
it can differe so much by the condition, compression ratio. as long as they are all within 10psi of each other the engine will be healthy, they really should be between 130psi-200psi
chones2083
Jun 2, 2005 06:48 PM
nachoman
May 23, 2005 02:37 PM
aquessada
Feb 21, 2005 03:00 PM
Dickie
Feb 10, 2005 06:24 PM
Blackhatch124
Nov 10, 2004 08:20 PM
