Connecting Rods
Old Jan 26, 2008 | 04:27 AM
bcrichguitars's Avatar
Default Connecting Rods
I'm getting some H Beam connecting rods formy JDM D15B. Will these rods fit?http://cgi.ebay.com/ebaymotors/Eagle...spagenameZWDVW
They are eagle part number CRS5394H3D. That has .748" wrist pin, 5.394' C-C Length,. 898" BIG END, and 1.771 crank pin.
This is the tunertoys versionfor JDM D15B but I cant get them shipped to Canada. Will the other ones work with my engine? Someone told me H-Beams aren't made inthe right length for JDM D15b.
I found a guy getting these and I might order some.
Rods and pricing:
JDM D15 Custom Length I beams(Only for JDM d15 crank)-->Intro price $276.25 ($325 regular price)(MSRP $399) 136.40mm length
Vitara Piston will be at .002 below deck height
Think I should get those?
Old Jan 26, 2008 | 04:47 AM
Default RE: Connecting Rods
sorry double post
Old Jan 26, 2008 | 05:31 AM
kokasian's Avatar
you can google it and see if the rod length is the same, wikipedia would help too
Old Jan 26, 2008 | 12:30 PM
"D15Z1 and D15B motors have a rod that is the same length as a D16. Other than the rod length, the rest of the bottom end is D15 spec (i.e. rod and crank bearings). D15B has D16 sized rod journals. D15B uses the same p28 rods that the D16z6 does. All other D15s have smaller rod journals."
So will any rods that say they work for D16, will work with my engine with Vitara pistons? That just confuses me more because this says D15B has 137mm rod length. But I foudn these "JDM D15 Custom Length I beams" they are 136.40mm length and it says Vitara Piston will be at .002 below deck height.
They also have "D16 Standard Length H beams" 137mm length and it says "This rod will fit any aftermarket piston (Vitara/CP/Wiseco/SRP/Arias...etc)".
Do you think I need the jdm d15 custom length I beams? They are slightly shorter in length, i'm confused. Any help would be appreciated.
D15B [ul][*]VTEC[*]Found in: [ul][*]1991-1999 Honda Civic VTi EG4 (Japanese Market) [ul][*]Displacement: 1493 cm³[*]Bore and Stroke: 75 mm X 84.5 mm[*]Rod Length: 137 mm[*]Compression: 9.6:1[*]Power: 130hp (97kW) @ 5800 rpm & 102 ft·lbf @ 4200 rpm[*]Redline: 7200 rpm[*]Fuel Cut: 7411 rpm[*]Valvetrain: SOHC VTEC[*]Head Code: P08 (same head as D16Z6)[*]Fuel Control: OBD-1 MPFI[/ul] [/ul] [/ul]
Old Jan 26, 2008 | 05:48 PM
kokasian's Avatar
I'm actually not entirely sure. I know the decreased displacement in the d16 is from decreased stroke..so I'd think the rods for a d16 would fit. You may want to research a lot more though, there's a reason I a z6 over a d15b...
Old Jan 28, 2008 | 01:18 AM
Ya I found out the JDM D15B uses d16 connecting rods. But the guy selling the vitara's said that d16 rods wont work with those pistons. I don't know why they wouldn't, does anyone know what connecting rods work with vitaras?
EDIT: Just found out, On a JDM d15b with Vitaras and Eagles the piston will stick out the top and you will have to run a Thicker HG.
Does anyone know what headgasket to use?
ant813
Oct 24, 2007 12:53 PM
92gt50
Sep 29, 2007 09:56 AM
AgentofDarkness
Jul 2, 2006 09:01 AM
Nail I3unny
Mar 20, 2005 08:41 PM
trentveronica
Aug 24, 2004 01:29 PM
