Could I put a '93 Integra engine in my '89 Civic?
B18A1
- NON -VTEC
- Found in:
- 1990-1993 Acura Integra usdm "RS/LS/GS" (DA9, DB1)
- Displacement: 1,834 cc (111.9 cu in)
- Compression: 9.2:1
- Bore: 81 mm (3.2 in)
- Stroke: 89 mm (3.5 in)
- Rod Length: 137.01 mm (5.394")
- Rod/Stroke Ratio: 1.54
- Redline: 6500 rpm
- Rev Limiter: 7200
- Programmed fuel injection
- Power: 90-91 Only: 130 bhp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
- Power: 92-93 Only: 140 bhp (100 kW) @ 6300 rpm & 126 ft·lbf (171 N·m) @ 5000 rpm
- Transmission: 90-91: A1,S1, cable
- Transmission: 92-93: YS1, cable
no you will need the integra's, motor, trans, axles, shift linkages, ecu, mounts
now does your civic have the dpfi or the mpfi ??? because if you have the dpfi you will need to convert and rewire your car to mpfi.
streetwill01lx
Apr 29, 2010 06:24 PM
kvh
Feb 22, 2008 10:15 AM
domex
Feb 12, 2007 10:24 PM
anonymous4l
Dec 15, 2005 10:53 PM
