Crower cam
Old Feb 2, 2005 | 08:38 PM
fast97's Avatar
Default Crower cam
Just found a crower cam for my HX for 315.00. It says on the nopi website all of the engine codes for 96-00 sohc motors check it out and tell me what you think.
Old Feb 2, 2005 | 08:50 PM
sacicons's Avatar
Default RE: Crower cam
its gonna KILL your mileage. itll basically change the vtec-e to normal vtec.
Old Feb 2, 2005 | 09:00 PM
fast97's Avatar
wel how could that work on the vtec-e motor due to the different valve train set up. Do you think if i took it to honda the would put it in for me Or could i do it cause i have done lots of bottom end work and lots of timing belts butt never messed with valve train at all. You would have to adjust the valves a little if i am not mistaken due to the different profiles, and the only people i would trust to do such a thing is honda. I might check put this new place here in cincinnati called raceline and see what they would charge.
Old Feb 2, 2005 | 09:06 PM
sacicons's Avatar
i think the only real difference is in the cam and tuning
Old Feb 2, 2005 | 09:14 PM
fast97's Avatar
Yes it is but it also has something to do with the rocker arms. Do you have a haynes manual handy if so look at chapter 2 a-7 it shows the complete differencein vtec-e and normal vtec.
Old Feb 2, 2005 | 09:23 PM
sacicons's Avatar
yeah, i dont have the manual, but ill look when i get a chance.
anyone who has a cam for vtec-e and regular vtec, compare them side by side and see if the lobes all line up and its the same size (not the lobes, the journals.)
keldon5
Nov 9, 2012 01:36 PM
DjHagios
Jul 29, 2010 04:38 PM
MemphisRyda
Jul 16, 2008 05:49 PM
TeamExodusPres
13
Aug 10, 2007 05:11 AM
koots
Aug 17, 2006 04:17 PM
