crower stage 3, too rich?!
Old Dec 2, 2005 | 07:52 PM
gambino's Avatar
Default crower stage 3, too rich?!
hi, would a crower stage 3 cams make the afr too rich, without timing ?
Old Dec 2, 2005 | 08:01 PM
StockSi's Avatar
Default RE: crower stage 3, too rich?!
dude, that question has no merit.
Old Dec 2, 2005 | 08:47 PM
fast93civic's Avatar
if using with stock motor, then too lean.
Old Dec 2, 2005 | 08:48 PM
AgentofDarkness's Avatar
The cams can only let air/fuel into the cylinder, the computer determines how much fuel enters the cylinder so no the cams can't lean or rich the AFR. The cam just opens the valves.
Old Dec 2, 2005 | 09:13 PM
StockSi's Avatar
for the most part yaa.. but the cams can lean it out. i can lean out stock injectors with my current cams but the engine will run fine on stock cams.
Old Dec 2, 2005 | 09:15 PM
You don't gotta make the guy feel like a dumbass, which is what i felt you were trying to do. It felt like you were saying ur a total dumbass for even asking that question.
Old Dec 2, 2005 | 09:22 PM
StockSi's Avatar
nope, just telling him it has no basis. how can you give advice when he has gicen next to no info?
Old Dec 2, 2005 | 09:52 PM
Think of it in this way. Stage 3 cams make a higher lift for a longer duration correct. For that period of time you have more air going in to the motor, but the ECU is still putting out the same amount of fuel in the motor due to closed loop. So, you have quite a bit more air going in to the engine, but just about the same amount of gas. This espeically matters when you're in the higher RPM's.
Old Dec 2, 2005 | 10:36 PM
The car has an air/flow meter, but the only thing that the cam could do to make it lean would be to bring more air into the cylinder than the fuel injectors could spray.
Old Dec 2, 2005 | 10:51 PM
XCM828's Avatar
I hope you know what you're doing. You can't just drop in a stage 3 cam. You're gona need all new super strong springs and retainers. Not to mention your gona have a tough time idling with that agressive of a cam. I'd say stage 3 isn't really necessary unless it's an all out drag car, or you drive to work at like 9000rpm every day.
