D15 to D16 questions
Old Jan 17, 2009 | 09:05 AM
you already have VTEC...
Old Jan 17, 2009 | 09:48 AM
ef9101's Avatar
no see he may not have vtec he could have a d16y7 but what u can do is fine a vtec head off a d16y8 swap it on your block for more horse, drop a intake + heads with stage 2 cams that will boost your car at most by 15 to 25 hp or more n swap a stage 2/3 clutch theres alot you can do to performance ur car jus takes money in time evrything happens with patients
-id say save up drop 4 a turbo about 2gran some kits go for 1800
or do a over all engine swap go DOHC
Old Jan 17, 2009 | 03:02 PM
He has an EX. He has a D16Y8. We have no reason to believe it was swapped, he hasn't mentioned it.
Old Jan 17, 2009 | 05:10 PM
stohlermatt's Avatar
It doesnt say vtech. Shouldn't it say it on the motor or on the outside? Cuz i thought vtech required a dual overhead cams? I have single i think...is there 2 different types of D16 engines?
Old Jan 17, 2009 | 05:16 PM
there are many types of D16 engines. All the D16 motors are D16xx. I have a D16Z6. You should have a D16Y8.
VTEC exists in some SOHC Honda engines, but it isn't "true" VTEC. You only have VTEC on the intake lobes on a SOHC VTEC engine, because the spark plugs are in the way. On a DOHC VTEC both intake and exhaust lobes are changed while VTEC is engaged.
Just because it doesn't say VTEC doesn't mean anything. The only D-series SOHC VTEC engines that really said VTEC were the 94-95 D16Z6 engines.
Also, if your motor says "vtech" you should be very worried, because someone must have swapped your engine with a cordless phone.
Old Jan 17, 2009 | 06:44 PM
Cyphen's Avatar
and 93 EX Ej2 coupe have d16z6 motors, my brother has the ex modle of the 93 coupe
Old Jan 17, 2009 | 06:46 PM
what does this have to do with anything?
i didn't say they didn't have d16z6 motors
Old Jan 17, 2009 | 08:13 PM
My engine is a D16Y8. Thats what it says on the engine. unfortunatley my car is auto, but ready for a tranny swap...SOON...I know N/A seems stupid, but in the long run, the car will last longer...do any of you know how many horses im putting to the ground now with a full exaust and mishimoto intake(that's supossibly "cold air intake")?
Old Jan 17, 2009 | 08:15 PM
full exhaust as in header and catback?
Old Jan 17, 2009 | 08:19 PM
catback custom piping
