D15B JDM Spec?
Old Dec 13, 2008 | 12:23 AM
Hailchristian's Avatar
Default D15B JDM Spec?
Honda civic forum...
this is a question that I know about ten of you can answer without thinking.
so i will ask it cause i don't know to much on the subject.
D15b JDM Spec...
this guy http://www.hmotorsonline.com/shop/sc...age&item=30021
My friend wants to drop it in his crx. Multiport is already wired. He currently has a DOHC zc with a DX or Si transmission (ef cable)
I still need to know about a couple things
1. Transmission? will his current transmission bolt up?
2. ECU? which is the best one to use/easiest to wire up?
3. Wiring? can we use his excising wire harness?
any information will help me..
if some one can just lay down...what i need, that would be hella cool.
Old Dec 13, 2008 | 06:47 PM
Alright..found out i can use the existing transmission.
1 down 2 to go
Old Dec 13, 2008 | 07:44 PM
2. use a P28
3. use existing harness, get OBD0-OBD1 ECU conversion harness, and distributor conversion harness. Both can be found on Phearable.net
I believe the above is correct.
Old Dec 13, 2008 | 07:51 PM
that was exactly what i was looking for...
thank you.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
ReSpEcT90210
Jul 24, 2007 02:07 PM
4doorcivic9
May 16, 2007 06:56 PM
POLYTHING
Feb 16, 2007 09:43 AM
boosted_honda
Jun 15, 2006 12:23 AM
