d15b vtec solenoid valve??
Old Jan 18, 2008 | 02:26 PM
hondacivicd15b2's Avatar
Default d15b vtec solenoid valve??
hi!i think something it is wrong on my vtec solenoid valve....it have the wire from the ecu but it i haven't the oil presure...i see some pics that theyhave a green sensor i think...the engine is from japan d15b with p08 ecu auto and i swap to manual....and have bolt is this point...what can i do??
Old Jan 18, 2008 | 03:08 PM
Default RE: d15b vtec solenoid valve??
help please!!!
Old Feb 10, 2008 | 01:11 PM
lilgreencivic's Avatar
did you remove the oil jet between #2 and #3 cylinders?
Pk
Old Feb 10, 2008 | 04:56 PM
ORIGINAL: lilgreencivic
Pk
wouldn't this only apply to a mini-me swap?
ORIGINAL: hondacivicd15b2
did you do a mini-me, or the whole swap?
do you mean that you swapped the transmission to manual? or do you mean you swapped the ECU to manual?
Old Feb 12, 2008 | 02:00 PM
I have it all figured out now... i think.... My first idea of a Mini-Me gone bad was do to me scanning and not fully reading the post. Did you swap to a p28 when you put in a manual???? cause if you did i think your problem is because the P28 ECU looks for the oil pressure switch and the JDM p08 ecu for the JDM D15b doesnt...therefore the JDM D15b does not have an oil pressure switch.... AND when a p28 doesnt find oil pressure it goes into "Safe Mode" which prevents large amounts of stress on the motor (stress like vtec) so that you dont trash your beaufiful d series.
I could be completly off the deep end again but this IS the problem IF you put in a p28
Pk
Booger
EK Swaps
Aug 9, 2011 10:11 PM
edmaxx
Jul 4, 2010 06:27 AM
marquez0721
Sep 19, 2008 07:19 PM
randommike88
Apr 28, 2007 09:26 PM
ivtec
Apr 5, 2006 06:47 AM
