d15b1 .... heads??? new engine??
Old Jul 12, 2007 | 05:02 PM
2slowhatch's Avatar
Default d15b1 .... heads??? new engine??
Ok so I have a question I have an 88 civic hatch with a d15b1 and i was wondering what d-series would be the easiest swap and alos if i could use a later model head on my current block beacuse its not multi port fuel injection so i wanted to do some sort of swap because i plan on turboing it later on and i dont wanna go with a b-series so i need to know what options i have with my current setup i wanna keep my same tranny and also not too much wiring so please let me know if anyone has any input on this....thanks
Old Jul 12, 2007 | 08:29 PM
4geazy's Avatar
Default RE: d15b1 .... heads??? new engine??
d15b vtec its what im doing
Old Jul 13, 2007 | 03:21 PM
2slowhatch's Avatar
which d15b are you using? and which head are oyu using and all that stuff???
Old Jul 13, 2007 | 08:20 PM
jeff948594's Avatar
d15b is a jdm engine with roughly 130hp SOHC V-TEC, you can pick up the engine for about 400-700usd but you would need a cpu and wiring too. the stock ecu and wiring from a 92-95 civic will suffice (i think) my 94civic ex had this swap when i bought it and the ecu is the same as a stock one and my car occasionaly throws a CEL but who cares when it runs fine. also im not sure about mounts or a trans but im sure that it will all bolt right up.
http://www.japanpowerinc.com/engines...p;id=D15B#spec
there is one for 480 engine only
but if you want to go from throttle body to multi point fuel injection there will be some wiring
Old Jul 13, 2007 | 09:19 PM
4geazy's Avatar
have you ever bought from japan power inc??
Old Jul 13, 2007 | 09:23 PM
jeff948594's Avatar
personaly, no but my buddy bought an swap for his 240sx from them, good customer service but he hasnt installed the engine yet so i cant testify to the quailty, it looks good and they have a report of all the tests they performed on it, so i would say they are reputable.
Old Jul 13, 2007 | 09:39 PM
4geazy's Avatar
thats good to know im thinking of buying from them
Old Jul 13, 2007 | 09:50 PM
jeff948594's Avatar
what kind of car are u plannin on droppin it in?
Old Jul 14, 2007 | 06:16 PM
2slowhatch's Avatar
mine is an 88 civic hatch
maachan513
Aug 13, 2011 06:06 AM
RowensSpecV
May 2, 2007 08:06 PM
greaseman
Apr 13, 2006 01:16 AM
rtriv
Jan 10, 2006 12:40 AM
315 Customs
Aug 9, 2005 11:52 PM
