D15B7 shaking on low rpms
Old Sep 19, 2013 | 05:58 PM
Stefanov191's Avatar
Default D15B7 shaking on low rpms
Hi to all. I have 95 civic 4dr with d15b7 on it. A few days ago the engine started shaking between 1000-3000 rpm but only when get warmed, when is still cold runs great. Today i took out the spark wires and the holes for the spark plugs were all in oil, which means i need new valve cover gasket, now is with silicone on it and obviously is bad. I bought new 4 spark plugs NJK-R and replaced the old ones, but no success. So where i should to look up for a problem, wires, coil, distributor, lambda sensor and etc. There are so many things who could be the reason for this so every help and advices are appreciate.
Old Oct 8, 2013 | 02:57 PM
itburnswhenIP's Avatar
could be the injectors try adding some Seafoam injector cleaner and se if that helps. also clean out your IACV.
antistar
Jun 19, 2007 06:10 PM
sickcivic07
Feb 16, 2006 04:51 PM
ten2doyle102
Dec 23, 2005 04:51 PM
civicexracer
Nov 13, 2005 12:53 PM
civicexracer
Oct 4, 2005 07:53 PM
