d16a1 performance build please read and reply
Old Apr 22, 2006 | 01:12 PM
89si's Avatar
Default d16a1 performance build please read and reply
have an 89 si crx im putting a d16a1 out of a gen 1 teg my goal is between 250 and 300 horsepower i wanna go turbo but not really sure what to do do to the engine i have it apart and tore down im building it from bottom to top im gonna go with low compreeion pistons chromoli rings im getting my roating assilmbally balanced addjustable cam gears stage 2 cams a p&p and oversized vavles skunk 2 intake exghust header a t3 turbo and a pg7 ecu can anyone else suggest any thing i should do to get good horse power please reply i need all the onfo i can get
Old Apr 22, 2006 | 01:14 PM
Mad7s's Avatar
Default RE: d16a1 performance build please read and reply
Geeze man! Way to shoot for the sky. Take some video when you get it to that.
Old Apr 22, 2006 | 01:17 PM
89si's Avatar
so their is no way i can get that out of it
Old Apr 22, 2006 | 01:47 PM
Mad7s's Avatar
I don't have the technical knowledge to say yes or no to that question. From what little I do know, I'd say it's a far reach. I've never heard of a 4th Gen Si engine making those types of numbers. If you got the never ending wallet though, then that helps quite a bit. I wasn't being sarcastic in my previous post, that was truly sincere. It's an unusual goal and if it's what your after then I say rock in.
Old Apr 22, 2006 | 04:05 PM
89si's Avatar
so what is a reasonable goal do u think
Old Apr 22, 2006 | 04:11 PM
Mad7s's Avatar
High 100s, but for the money it will probably take you could drop a b16 in there and already be at that range.
EDIT: High is spelled H-I-G-H not H-I. Damn I'm stupid.
Old Apr 23, 2006 | 12:05 AM
Kappa22's Avatar
Nah, you can hit mid 200s without too much trouble on boost.
That swap is kind of a biznatch though, since the mounts are different. A DOHC ZC is easier and more powerful out of the box (i.e. direct bolt in).
Old Apr 23, 2006 | 12:11 AM
Nail I3unny's Avatar
DOHC ZC or B16A1. both are direct drop ins that require a little work but both are well worth it.
Old Apr 23, 2006 | 06:56 PM
kimsuprapa's Avatar
ORIGINAL: Nail I3unny
2nd that.
Old Apr 23, 2006 | 09:18 PM
89si's Avatar
so im going the right way with the d16 glad to here that
