d16z6 distributor
Old Jun 13, 2009 | 09:29 AM
Originally Posted by candyman420
ok so the volt reading and ohm ready jumps all over with the key off when i turn key on the ohm is 0.L witch i think is good but the volts is 5.90 is this enough?? im thinking of just running my own jumper wire..???
You need to tell me what wire(s) you are testing and how you are doing the test.
Old Jun 13, 2009 | 09:38 AM
candyman420's Avatar
this test was the yel/grn wire... i have a tester volt tester.... i clamped on the wire by the distributor and then poked the same wire (yel/grn) by the conectors before it goes into the car to the pcm...
Old Jun 13, 2009 | 10:04 AM
Your voltage and resistance tests don't tell you much the way that you are doing them. Avoid testing this wire with the key ON. This wire is only tested with the key OFF. Disconnect the wire from igniter and the respective connector at the ECU. From the free ends, test for continuity to ground. Continuity would indicate a short (=bad). Next test for continuity between BOTH ends. No continuity would indicate an open (=bad).
THE_FATTIE
Apr 29, 2010 07:50 PM
tico2626
Aug 10, 2006 03:59 PM
baker7598
Jun 21, 2005 11:47 PM
ohbiskits
Dec 6, 2004 09:32 PM
mcbob
Nov 22, 2004 03:24 PM
