D16z6 help please!
Old Jul 12, 2007 | 11:04 PM
LarsonSi_0091's Avatar
Default D16z6 help please!
ok i got d16z6 and i got the timing alined on the timing belt n when i went to go check the dizzy the and it didnt aline up with the cam. does anyone have and suggestions?
Old Jul 13, 2007 | 03:33 AM
Default RE: D16z6 help please!
please be more specific, what do you mean it didn't line up with the cam? The dizzy only goes on one way, so just turn the rotor shaft until it slides in.
MAKE DAMN SURE that your motor is at TDC and the rotor is pointing towards the number one terminal
Old Jul 13, 2007 | 09:13 AM
i had someone helping me and he said when the motor was at TDC that the rotor in the dizzy had to line up with the cam and a mark inside the dizzy to set the ignition timing but i cant it to line up inside the dizzy when the motor is at TDC.
Old Jul 13, 2007 | 09:58 AM
Check the mark on the crank gear in relation to the arrow on the oil pump. When that is aligned, the "7 oclock" mark on the Cam Gear should be aligned with the little plastic arrow in the timing cover.
My guess is that its a tooth or so off.
Old Jul 13, 2007 | 12:46 PM
ok so i got the timing all on to the cam and crank and the motor at TDC. are you saying that the screw or the fin that makes spark should be pointing toward the number 1 terminal?
Old Jul 16, 2007 | 03:40 AM
The tip of the rotor that runs next to the number 1 spark plug wire's terminal
Ek98
Nov 30, 2006 12:43 PM
MrNightRyder
Jul 1, 2006 05:11 PM
MrNightRyder
Jun 29, 2006 07:37 PM
Honda99Civic
Apr 20, 2006 10:13 PM
fast93civic
Dec 17, 2004 03:06 PM
