different idles
Old Apr 24, 2006 | 04:33 PM
slottieskim's Avatar
Default different idles
i have a lot of dumb questions... but some times i start my car and in neutral cold, it idles at about 1700 and other times i start it and its at about 900... then after driving idle is down to about 500... then if i turn it off for about 10 minutes and start it, the idle is back up to 1500 or somewhere around there. what could be happening?
Old Apr 25, 2006 | 07:59 AM
Default RE: different idles
Sounds perfectly normal to me. It will Idle higher when you first start it up to make sure oil and everything is pumped through the system. In a nut shell, the motor is "warming up." Once it's warmed up, it will drop down to around 500-700rpms, mine sits at 500 most the time.
CivicSiSolja
Dec 7, 2006 12:17 AM
Liebers19
12
Oct 3, 2006 12:24 AM
VTECivic95
14
Aug 2, 2006 10:36 AM
baker
Feb 24, 2006 05:57 PM
redtide265
Apr 27, 2005 09:28 PM
