Distributor Help.
Well I assume it's my distributor because when I idle it's usually almost to 0 (so i guess like 200-500) but when I drive it's normal. The car doesn't die when I shift gears or anything. I don't know anything about cars so any help would be very much appreciated.
It's a 97 Honda Civic Ex Coupe Automatic.
Is the CEL ON?
Based on your information, I'd classify the problem as "low idle".
Start by cleaning the IACV on the throttle body (see IACV link in my signature).
Also, when was your last basic tune up (plugs/wires/cap/rotor)?
Start ^ and then clean the IACV thoroughly if the idle problem persists. Actually, you might first want to check the ignition timing with a timing gun after the basic tune up, which is definitely a DIY job if you want to save money.
xiongskies
Feb 22, 2007 04:36 PM
Xemu
Aug 24, 2006 11:37 PM
rodbuster
Jan 26, 2006 06:51 AM
