eagle rod clearance issue
Old Jul 30, 2008 | 06:09 PM
silver wrench's Avatar
Banned
Default eagle rod clearance issue
i'm putting eagle rods in my d16z6, the rod bolts don't clear the main bearing cap, how do i correct this problem? thanks in advance!
Old Jul 31, 2008 | 01:29 PM
riceburner700's Avatar
you have to shave a grove into the girdle so they will fit and rotate without binding
Old Jul 31, 2008 | 09:02 PM
gsumano's Avatar
Like riceburner said, you have to notch your block...
here's a link of a td16 member notching his block... so you can get an idea
http://www.turbod16.com/viewtopic.ph...it=notch+block
Old Aug 2, 2008 | 05:17 PM
Banned
thanks guys, that what i thought i had to do but just wanted to make sure, just curious but what would happen if i cut out those center pieces?
mudhenFUF
Jan 16, 2023 08:43 PM
redraif
Mar 7, 2013 01:59 PM
Peg_Leg
Aug 8, 2010 09:27 PM
92sickw/it
Jan 9, 2007 01:55 PM
rdas45
37
Jul 8, 2006 12:29 PM
