Engine mount shot
Old Feb 14, 2010 | 08:15 PM
denny8569's Avatar
Exclamation Engine mount shot
I am little upset to see the engine mount on top of the engine that connects to the cross bar is shot. The rubber is all torn and ripped apart. I am upset because the car was in the dealership
the other day and they should have seen this. Going back in on tuesday and they will hear an earful. If the part was $20 bucks I would fix it myself but the part is like $250 bucks.
Old Feb 14, 2010 | 08:48 PM
GReddy_Civic's Avatar
Snail'n Admin
what car? I have a full set of oem mounts for my 97 civic that was rear ended. I believe they were all good when I removed them
Old Feb 14, 2010 | 10:19 PM
That mount does not cost $250. Check the Majestic Honda site.
Old Feb 16, 2010 | 05:49 PM
You're upset that they didn't find the issue when the car was in for servicing previously? B/c they would have just charged you the $250 at that point. So, I hope you are not mad about the money it will cost.
I guess I would be a little irritated seeing that you have to bring the car back a second time, but something like this doesn't deserve "an earful".
Old Feb 17, 2010 | 03:21 AM
You have several cheaper options. A used mount will work fine. Or you can convert your broken mount into a solid polyurethane mount using this DIY: https://www.hondacivicforum.com/foru...ad.php?t=80490
Old Feb 26, 2010 | 04:13 PM
StifflersMom's Avatar
Cat Fuсker
Do that. If you end up not liking it you can always buy a mount to replace your already shot mount and this will only cost you $17 to do.
fridge
Apr 19, 2005 12:25 AM
ohbiskits
Feb 13, 2005 03:04 PM
addy79
Feb 5, 2005 11:43 AM
94d15z7hatch
22
Jan 5, 2005 11:14 AM
induction1
Nov 1, 2004 06:37 PM
