go b20b vtec or stay b16a?
Old Aug 31, 2006 | 03:30 PM
95 Civic B16A's Avatar
Default go b20b vtec or stay b16a?
havn't been on in a while... so i was wondering if i should go b20b and put my b16a vtec head and obd1 computer or just stay b16a?thanks
Old Aug 31, 2006 | 03:35 PM
rice_patrol's Avatar
Default RE: go b20b vtec or stay b16a?
i would rather stay b16a. The b20/vtec will break down on you sooner or later. I personally dislike ls/vtec and b20 vtec.
Old Aug 31, 2006 | 03:39 PM
ef4life's Avatar
how do you drive your car??
Old Aug 31, 2006 | 03:50 PM
Marty's Avatar
CR/VTEC > B16, build the bottom end and do it
Old Aug 31, 2006 | 04:23 PM
yeah i planed on using a toda racing bore kit, and building the bottem end. i also planned on putting itb's on it.of course sometime rebuilding every thing in the engine. first would be bottem end, then head,then internals(toda racing bore kit), then bolt on's. i think that is planed out well.do you?
Old Aug 31, 2006 | 04:26 PM
Marty's Avatar
dont bore or stroke it just buy a good set of crower rods, weisco pistons, and arp bolt's and studs throughout. Also use honda gaskets throughout.
Old Aug 31, 2006 | 05:00 PM
how come i shouldn't bore it. i would just like a reason. thanks
Old Aug 31, 2006 | 05:54 PM
finalimpact's Avatar
theres a guy down here with a b20vtec. only thing done to the bottom end is arp rod bolts. 17k miles in 3 years and no breakdowns worth mentionin(ie:due to the combination)
Old Sep 1, 2006 | 06:37 PM
thakid's Avatar
I would stay with the B16 because of the thin side walls on the B20.
what is wrong with the LS with the V-tec head swap? if you ran into any problems on it let me know cause i am about to swap a LS (V-tec) into my 4 door EG.
Old Sep 1, 2006 | 07:04 PM
Marty's Avatar
Dude the cyl walls are 3mm thinner or 0.1181 inches thinner. That spread around the whole cyl wall = nothing to worry about really. This is a over hyped myth that is complete bs.
