H vs. B
So as of now I wanna get a H22A JDM cause of its high stock numbers. But I heard the B's (Best one the B18C5?) take mods very well and they seem to be all the hype right now. I heard the H cant be bored as much as the B cause of its thin sleeves. Well my question is, will the H out do the B? I will be adding a turbo to the engine I buy. But in the end will the H with its high numbers blow away a B...both modded to the teeth?
I know if youre gonna turbo a B you should use the B18C1 over a B18C5. As for the B vs H do a search (at the top of the page) and find out all the advantages and disadvantages as this topic has been gone over a lot
h's cant be bored very far due to the frm sleeves...........however you can sleeve them and go from there. stock for stock the h will out do the b..........depending on your funds though will dictate how far you can take either engine. i would go h for the larger displacment as well as initial cost.
honestly, I would rather have a stock k20 with a basic turbo kit than either one with a mild build and a turbo. look into the K20. its a more expensive swap initially, but in the long run, its definately the best choice if you can swing the initial layout of money.
ORIGINAL: sacicons
