H vs. B
Old Aug 28, 2006 | 11:35 AM
  #21
99civicricer's Avatar
Default RE: H vs. B
I dont know if i want to boost it though because i will have this car for a while, and it needs to be a daily driver also. Would it be better to get the b18c it-r and do the I/H/E and change internals and new fuel injection. Or the b18 gsr and do everything i would to the it-r minus the header but boost it
Old Aug 28, 2006 | 11:42 AM
  #22
Kedawei's Avatar
Default RE: H vs. B
These motors are already fuel injected.
http://auto.howstuffworks.com/engine.htm
Old Aug 28, 2006 | 12:50 PM
  #23
Nail I3unny's Avatar
Default RE: H vs. B
ORIGINAL: 99civicricer
you wouldnt use the intake either.
Old Aug 28, 2006 | 04:31 PM
  #24
Default RE: H vs. B
i meant a c.a.i. i know it is already fuel injected, but i meant if i could get a better fuel injection
Old Aug 28, 2006 | 09:09 PM
  #25
BallardCivic's Avatar
Default RE: H vs. B
Go GSR man. The sleeves on the H22 leave me a little squeamish, and everyone gets a little boost happy, so if you go B18, youre going to have a really good base to move up on. The H22 is a great motor, for maybe even a little less, after all is said and done, the B18 might be cheaper, and youll be better off in the long run IMO.
At 8psi you wont need to worry about better fuel injection, youll most likely be okay with what you if you get a good tune.
Old Aug 28, 2006 | 09:42 PM
  #26
Default RE: H vs. B
H22 sleeves are no thinner than GSR sleeves.
and yes, i meant CAI too. you wont use it when you get a turbo unless you modify it to use as charge piping.
Old Aug 29, 2006 | 06:27 PM
  #27
glada96EX's Avatar
Default RE: H vs. B
You probably would get a better daily driver boosting a gsr than running a built type R. If you just want a car that does 14.5 seconds and is fun to drive, get the b18c5 and put a H/I/E and call it good.
Old Aug 29, 2006 | 07:44 PM
  #28
Default RE: H vs. B
If just wants basic stuff, theres no way he should get the Type R. Too expensive compared to the H22.
Old Aug 29, 2006 | 08:12 PM
  #29
AllForSRT's Avatar
Default RE: H vs. B
built LS block
Ported C1 head
GT40 Turbo
Game over... lol
Old Aug 29, 2006 | 08:28 PM
  #30
Default RE: H vs. B
i am gonna run 8 psi but when i race someone i want to put it up to like 13 or 14 psi. But i want to be able to go low 13
