Head Milling vs. Larger Piston!!!
Ok :P let me add. this will be my daily driver once i sell my Neon.. i want to keep it streetable . so idle etc.. are a factor as well as gas.. also reliability
id only mill the head or the deck if its not true.......milling either head or deck can throw your cam timing off which you have to compensate for with adjustable cam gears. the only draw back to going with a larger piston is the cylinder walls become thinner and if your not sleeved they are that much weaker.
ORIGINAL: Kedawei
This is something I've always wondered. What is the limit of our little D-series's on 91 and 93 octane, compression wise?
ORIGINAL: ef4life
i wouls say the maximum amount possible for a dd and street gas 91 octane or 93 octane.
ORIGINAL: ef4life
depends on who is doing the tuning and how good they are, and what components you use in your buildup.
ORIGINAL: Kedawei
ORIGINAL: ef4life
well for me as stated before.. Jeff Evans at www.evans-tuning.com would be doing the neptune job for me.. and machining and install would be done by local shops that work directly with him..currenly looking at refreshing complete oem bottom end and then the full headwork with most likely crower stage 2 or 3 valvetrain and adjustable cam gear.. lvl of cam would depend on what problems i would run into for daily driving and if stage 3 would be too much..
ORIGINAL: Kedawei
With a good tuner and proper components?
ORIGINAL: ef4life
ORIGINAL: Kedawei
ORIGINAL: ef4life
addiction2bass
Sep 27, 2007 06:08 PM
maxrapp
Nov 30, 2004 05:46 PM
