help :(
Old Jul 18, 2009 | 10:54 AM
  #21
candyman420's Avatar
Originally Posted by RonJ
89 Civic: Fuse 37 (15A) in the main fuse box.
under the hood main fuse box or under dash?
Old Jul 18, 2009 | 10:56 AM
  #22
Originally Posted by candyman420
i didnt take it out when i did the test and i didnt puch the gas down either will this make a diffrence?
To get meaningful results, do the test EXACTLY as described at the link!!!
Old Jul 18, 2009 | 11:00 AM
  #23
Read my reply:
Old Jul 18, 2009 | 11:03 AM
  #24
10 4 good buddy!! calm down with ur red letters lol
Old Jul 18, 2009 | 11:24 AM
  #25
Just thought you might need some special prompting to make you read instructions more carefully.
Old Jul 18, 2009 | 11:39 AM
  #26
well with doing the way the intsructions tell me the compression is even lower then it was before.... #1 is still at 140 but the rest of them dont even make it to 100... want to buy a crx any1?
Old Jul 18, 2009 | 12:03 PM
  #27
Is the ECU fuse removed so that no fuel is squirting into the cylinders? If so, repeat the compression tests with a teaspoon of motor oil added to each cylinder (=wet test). If the values increase substantially, the piston rings are bad. Were the block and head from running engines?
Old Jul 18, 2009 | 12:15 PM
  #28
the block is the same one i was testing on like a month or so ago when we was having this convo... im sure the rings r bad.. im not wasting my time on it any more.... im gunna buy a ford... lol yes they r both from running motors..
Old Jul 18, 2009 | 12:27 PM
  #29
By the way, if the cylinders were flooded with fuel during your tests, then your compression values would be artificially low.
Old Jul 18, 2009 | 06:08 PM
  #30
i will give it 1 more try tomorow...other wise i posted it up on craigslist already....
