here is my performance part list.
Old Feb 21, 2006 | 09:11 PM
95 Civic B16A's Avatar
Default RE: here is my performance part list.
so should i forget the pulley's?
Old Feb 21, 2006 | 09:15 PM
AgentofDarkness's Avatar
Thats gonna be my advice. The max you have to gain is like 10hp i believe. I don't think its worth it
Old Feb 21, 2006 | 09:17 PM
will it hurt my car in any way or are they a good thing?
Old Feb 21, 2006 | 09:21 PM
The only way that i could see them as hurting your car is that it might make the alternator output lower. If the output is lower, and the alternator isn't making enough energy to recharge the battery, then you might end up having your battery be dead. Other than that, i can't think of them hurting your car. But to me, they should be the absolute last thing you should do, well not the last thing but pretty low on the list.
Old Feb 21, 2006 | 09:23 PM
are the injectors to big or does it not matter how big they are? they won't hurt my engine any will they?
Old Feb 21, 2006 | 09:27 PM
The size of the injectors definatly matters. If you use injectors that are too big, your gonna end up running a very rich motor which isn't so good. If you use injectors that are too small, then your gonna run lean (which might be worse). As for what size you need, i don't know but someone on here prolly will.
Old Feb 21, 2006 | 09:54 PM
Nail I3unny's Avatar
ps if you're gunna build, build all the way. dotn get a turbonetics kit. if you're gunna get any 'kit' you should get a Full Race stage 4 on a setup like that
Old Feb 21, 2006 | 10:19 PM
Pete's Avatar
Injector Specs
Old Feb 21, 2006 | 10:32 PM
What about my ECU question pete?
Old Feb 21, 2006 | 10:57 PM
Pete's Avatar
ORIGINAL: AgentofDarkness
Well i figure the turbo should cost around 4-5k, so then the ECU is gonna cost 10k+? Thats a lot, makes me reconsider wanting to run 22lbs, definatly don't have 10K for ECU.
You dont need to buy the GReddy Emanage ultimate.....its just a piggy-back unit anyway. You can get AEMs EMS Standalone for like $1,000. It replaces the entire ECU.......Or u can get your P28 chipped with Neptune or Uberdata, and get that tuned........remember guys its not about how much boost youre running, its your power level.......a good tuner can make nice power on low boost numbers...............thats what you want. I think EMANAGE Ultimate is 450$......but AEM EMS is so much better for a built motor.
