High Boost B16A2
Old Nov 8, 2005 | 03:46 PM
alkalinecivic's Avatar
Default High Boost B16A2
If I wanted to run a B16A2 at around 15 or 20 psi, what kind of bottom end work would I need to get done first?
Old Nov 8, 2005 | 04:04 PM
Nail I3unny's Avatar
Default RE: High Boost B16A2
sleeved, forged pistons and rods, 4340 billet crank. youd need headwork done too.
Old Nov 8, 2005 | 04:16 PM
Remmy's Avatar
And make sure it will be able to re-enter earths atmosphere.
Old Nov 8, 2005 | 04:55 PM
Bunny,
whats a 4340 billet crank?
and when you say "headwork" what would you have in mind?
Old Nov 8, 2005 | 06:34 PM
Remmy's Avatar
cams... and head. So it can handle the pressure
Old Nov 8, 2005 | 08:18 PM
Pete's Avatar
you dont really need any headwork done other than a Forged crankshaft. The bottom end is whats NEEDED to be built. Forged rods, pistons and a sleeved block. Then youll need some RC injectors and a nice tune.
Old Nov 8, 2005 | 08:57 PM
sacicons's Avatar
a forged crankshaft isnt headwork Pete. im so confused right now.
anyway. 15-20 (which is actually a huge gap, because the prep for a decent 15 would keel over and die at 20, but I digress...)
youll need new forged Con-rods, forged pistons, probably no higher than 9:1 CR, SS valves, and if you wanted a solid 20PSI motor, with daily drivable reliability, then you will need to sleeve it. 15 you might get by with a very good machine shop installed blockguard, not just one tapped in with a hammer. never ever ever do that. it will very likely push the cylinders out of round, and cause catastrophic meltdown when you push it hard. a machine shop can realign the bores to make sure they are round after the install, as wel as weld the thing in and remachine the head surface. but your best bet is sleeves. well worth the money IMHO. oh, and all ARP hardware, along with a bunch of little deatils that im not going to bother going into because youre probably just curious, and a competent machinist would recommend them anyway. oh, and the stock crank will be totally fine. a b-series crank is totally reliable up to and well over 5-600hp. maybe chamfer the oil passages, and clean it really well and a little micropolishing on the bearing surfaces, but again, the machinist should reco that stuff anyway.
bloselogging
Aug 15, 2009 07:59 PM
Captain_Sl0w
Oct 4, 2008 03:05 AM
usmc2b2004
Feb 27, 2006 12:06 AM
str8racn
Nov 10, 2005 11:53 AM
nachoman
May 23, 2005 02:37 PM
