Holley 68mm TB.
Old Jan 7, 2009 | 02:50 PM
S/C SI's Avatar
Default Holley 68mm TB.
A friend of mine gave me a brand new 68mm throttle body from Holley. It's for my 95 D16Z6. I realize that the manifold would need to be ported to match. Is anyone here running one? Pros? Cons? Thanks.
Old Jan 9, 2009 | 12:37 PM
S/C SI's Avatar
Nothing?
Old Jan 9, 2009 | 09:46 PM
Not using one, but i'm sure it'll be fine since it's a reputable name brand. But yea, IM will have to be port matched as you said.
Though, what I would do in your situation is sell the Holley throttle body and just buy a larger than stock Honda throttle body like a 60mm one, to make some cash. I've heard that 68mm is pretty unnecessary, and that ~60mm is more optimal.
Old Jan 10, 2009 | 08:29 AM
S/C SI's Avatar
Yeah the 68mm is quite a bit larger. For some reason I was thinking stock was 65ish when I took it. Even if I got a 60mm I'd still have to port the IM as it is only 56ish. I did some more reading on porting the IM. Apparently it's not a good idea to port the stocker that much as it will cause idle issues and possible vacuum leaks. If I want to use the 68mm TB I'd have to get an aftermarket IM too.
Old Jan 10, 2009 | 10:42 AM
stock TB is 56mm (just an FYI) - I think you figured that out already though
If you end up getting an aftermarket IM, i'd go with an edelbrock performer X.
Old Jan 10, 2009 | 01:01 PM
S/C SI's Avatar
Yeah I read the sticky about the TB sizes. The performer X is nice. Most aftermarket IM's are 62mm so I'd still need to do some port work to take full advantage of the 68mm TB. Thanks for the help.
Street Sniper
Intake, Header, & Exhaust
15
Aug 22, 2008 02:25 PM
Fiasco
Aug 29, 2006 08:08 PM
psychocivic
May 1, 2006 06:45 PM
WillVTEC
Jun 7, 2005 05:07 PM
fast93civic
Nov 27, 2004 01:02 PM
