how can i get a compresion test??
Old Aug 10, 2006 | 08:56 PM
HaZe89's Avatar
Default how can i get a compresion test??
Hey guys hoy the heck can i run a copressio ntest to my car?? though i was wondering my engine has 175.000 mileage if y do and engine reparation (as i said) i mean replacing pistons, hihg compression, rods, valves you know everything inside it .. the jod cost like 500 bucks or more.. if i do that to my engine i have guarantedd that it can last 200km more??? or it will die the same soon if i do that job or not??
Old Aug 10, 2006 | 09:40 PM
riceburner700's Avatar
Default RE: how can i get a compresion test??
to do a compression test you have to have a compression gauge with the rubber hose you screw into a spark plug hole...
step by step
1. pull out all spark plug wires and set them on top engine
2. pull out all spark plugs
3. screw gauge into spark plug hole #1
4. crank car for about 5 seconds
5. read gauge and write number down
6. screw gauge into spark plug hole #2
7. crank car for about 5 seconds
8. read gauge and write number down
9. screw gauge into spark plug hole #3
10. crank car for about 5 seconds
11. read gauge and write number down
12. screw gauge into spark plug hole #4
13. crank car for about 5 seconds
14. read gauge and write number down
all the numbers should be no farther apart then 10psi
hope this helps
Old Aug 11, 2006 | 01:46 AM
tlthehun's Avatar
Please remember to disable the ignition coil by pulling the ECU fuse. I just replaced a coil that I fried because I didn't keep the ignition from firing while doing a compression test.
https://www.hondacivicforum.com/m_24..._1/key_/tm.htm
You'll also get more repeatable and universal numbers if you hold the throttle wide open while cranking.
In addition to a compression test to tell you about the top end, connecting a mechanical oil pressure gauge will give you some insight to the condition of the bottom end.
Old Aug 11, 2006 | 08:07 AM
ORIGINAL: riceburner700
step by step
hope this helps
Just to add, even though tlthehun just said it, it's best to hold the accelerator ALL THE WAY to the floor while cranking.
Old Aug 11, 2006 | 11:11 AM
rit14623's Avatar
ORIGINAL: HaZe89
If your car is normally aspirated, I doubt you will need to replace the pistons, rings, rods and valves. If the compression is low, a new head gasket would be good to replace.
sargentpilcher
Apr 11, 2013 04:01 PM
1992 civic driver
Sep 3, 2010 09:51 AM
enigma34
Sep 29, 2009 12:12 PM
tombakers
Oct 6, 2007 12:15 AM
addiction2bass
Sep 3, 2007 05:56 PM
