i have s stupid question
Old Apr 19, 2008 | 09:13 AM
soloxcivic's Avatar
Default RE: i have s stupid question
ORIGINAL: macbeth18288
what are you driving?
year? engine? etc?
94 ex 1.6L
Old Apr 19, 2008 | 11:05 AM
2 seconds in the 1/4? You're going to need a turbo or a supercharger to do that unless you have some deep, deep pockets
Or you could get an h22 swap for around $4k all said and done and run 13's without boost
Old Apr 19, 2008 | 02:54 PM
soloxcivic's Avatar
yah well im trying to get a job to save up 2k for a full install of the 15 inch orion hcca
Old Apr 21, 2008 | 05:51 PM
dmonger's Avatar
Dropping a full two seconds off your time is going to be difficult and expensive. The easiest and cheapest way to drop "some" time of you 1/4 is to fully gut the car, seats, ac compressor abything that adds weight. There are a few other tricks I heard around the way like running with lower tire pressure, about 18-1/4 tank of gas stuff like that. But doing all that may only drop your time by .5 at the most I'd say. Your not gonna be able to beat a Talon without shelling out a good some of money unfortunately.
Old Apr 21, 2008 | 05:55 PM
jamned's Avatar
Running with a lower tire pressure increases tire flexing, creating more rolling resistance. I don't see how that can improve your acceleration.
Old Apr 22, 2008 | 02:18 PM
dmonger's Avatar
Nor can I. That's why I said its stuff I've heard. I've never tested it personally.
Old Apr 22, 2008 | 06:45 PM
NorthWestPerformance's Avatar
The quickest, easiest, and cheapest way to get the most power out of your car is Nitrous which IS very safe if used properly. 94 ex/stock motor would take a 75HP shot nicely. That would be anywhere from $600-$1500 installed depending on what system and options you go with. Even then you still won't be 2 full seconds quicker most likely. So get your computer tuned too. You can easily gain horsepower just by altering the factory tune/program in the computer, especially when it's tuned FOR nitrous.
As far as letting air pressure out of the tires, only help on the starting line for traction. After that, rolling resistance will kill your times.
flyguyz718
Feb 11, 2008 08:37 PM
dj_ipirate
Nov 1, 2005 10:41 AM
wickedx
Feb 18, 2005 03:14 PM
StifflersMom
Jan 24, 2005 10:31 AM
StifflersMom
Jan 20, 2005 11:03 PM
