K Series FAQ
Old Nov 9, 2005 | 10:06 PM
es2001civic's Avatar
Default K Series FAQ
Im not sure if this has been posted before but I figured I would post it for those who might find it informative.
http://www.hybrid-racing.com/articles.html
K20a-JDM ITR and CTR both come in with 11.5:1 compression and 2 liters of displacement. The Type R motor is rated at 220hp at 8,000rpm and 152lb-ft at 7,000 rpm. Both of these motors have the same VTEC mechanism as the older B series motors but with the addition of VTC. It also has larger cams, higher compression and larger intake manifold than the Type S motor. This motor comes with a 6 speed transmission and LSD. The 6-speed manual transmission uses multiple synchronizing cones for all gears, including a triple-cone synchronizer in 1st and 2nd gears and a double-cone synchronizer in 3rd through 6th gears.
K20a2-Acura Rsx Type S has 11.0:1 compression and 2 liters of displacement. The Type S is rated at 200hp at 7,400 and 142 lb-ft at 6,000 rpm. This motor also comes with a 6 speed transmission with no LSD. It has the same VTEC mechanism as the older B series motors but with the addition of VTC.
K20a3-Acura Rsx Base and Civic SI models come in with 9.8:1 compression and 2 liters of displacement. The Base motor is rated at 160hp at 6500rpm and 141lb-ft at 4000 rpm. This motor does not use the conventional VTEC mechanism from the earlier B series motors but does have VTC. Instead it only has 2 cam lobes on the intake side and 1 on the exhaust lob. This motor has no VTEC mechanism on the exhaust cam and runs on 12 valves before 2200rpm with the other 4 slightly opening. It also has smaller ports than the Type S and Type R. The motor comes with a 5 speed transmission instead of the 6 speed and has no LSD.
K24a1-Honda CRV comes in with 9.6:1 compression and 2.4 liters of displacement. The motor is rated at 160hp at 6000rpm and 162 at 3600 rpm. This motor does not use the conventional VTEC mechanism from the earlier B series motors but does have VTC. Instead it only has 2 cam lobes on the intake side and 1 on the exhaust lob. This motor has no VTEC mechanism on the exhaust cam and runs on 12 valves before 2200rpm with the other 4 slightly opening. It also has smaller ports than the Type S and Type R. The motor also comes with a 5 speed transmission instead of the 6 speed and has no LSD.
K24a2- The Acura TSX comes in with 10.5:1 compression and 2.4 liters of displacement. The motor is rated at 200hp at 6800rpm and 166lbs-ft at 4500rpm. This motor uses the conventional VTEC mechanism as the older B series motors but with the addition of VTC. This motor uses a drive by wire throttle and has EGR castings on the manifold. This motor comes with a 6 speed transmission and no LSD.
K24a4- the Honda Element and Accord come in with 9.7:1 compression and 2.4 liters of displacement. The motor is rated at 160hp at 5500rpm and 161lbs-ft at 4500rpm. This motor does not use the conventional VTEC mechanism from the earlier B series motors but does have VTC. Instead it only has 2 cam lobes on the intake side and 1 on the exhaust lob. This motor has no Vtec mechanism on the exhaust cam and runs on 12 valves before 2200rpm with the other 4 slightly opening. It also has smaller ports than the Type S and Type R. The motor also comes with a 5 speed transmission instead of the 6 speed and has no LSD.
Old Nov 11, 2005 | 10:48 AM
z6 FoRiLLa's Avatar
Default RE: K Series FAQ
i would die for a k20a2
Old Nov 11, 2005 | 11:33 AM
Ive been scavaging the junk yards to see if i get lucky and get a good deal on one.
Old Nov 11, 2005 | 05:45 PM
mxs's Avatar
mxs
ORIGINAL: es2001civic
LOL, let me know how that works out for you
Old Nov 13, 2005 | 01:00 PM
Nail I3unny's Avatar
no way. K20A all the way
Old Nov 13, 2005 | 06:35 PM
BallardCivic's Avatar
Geez, now I want an RSX. If only I had 50 grand to drop.
Old Nov 13, 2005 | 11:41 PM
Kappa22's Avatar
If you had 50 grand to drop on a car, I hope you would consider something besides an RSX... New, the Type S starts around $23k; not quite 50...
Old Nov 14, 2005 | 08:52 AM
Yeah, but the other 27 grand would be spent on making the car better, well maybe not quite THAT much, but a good chunk of change.
tarheels131
Dec 31, 2023 09:12 PM
xposigroovex
May 31, 2006 05:00 PM
Patrick
Feb 6, 2006 08:46 AM
Marty
Dec 9, 2005 02:16 PM
bleedhondos
May 19, 2005 04:54 PM
