k20 swap
Old Oct 2, 2006 | 08:48 AM
juanlamonaca's Avatar
Default k20 swap
hey hows it going i'm about to buy a k20 type-r for my ek but i wanted to know what i would need besides what it comes with and also i heard that when doing the swap its hard to get the guages to work is this tru
Old Oct 2, 2006 | 09:10 AM
HARI.'s Avatar
Default RE: k20 swap
you will need to buy hasport mounts. www.hasport.com
you will need to send your engine wiring harness from the k20, and your stock engine harness to hondata.
you will need to send your k20 ecu to hondata
you will need to modify your axles.
you will need to change your steering rack and put an EG steering rack(92-95 civic)
you will need to buy fuel hoses, and fittings.
and about the gauge cluster, you will need to use your stock one. it will work.
if you were in cali, i could do it for you
Old Oct 2, 2006 | 09:17 AM
thanx for the help i heard that for the k20 you also had to move the radiator is that tru, by the way do you kno anyone in florida who does k20 swaps
Old Oct 2, 2006 | 10:34 AM
ProjectGSR's Avatar
heres a great site you should look at. its got a parts list for this swap.
http://www.hybrid-racing.com/fabrication.html
Old Oct 3, 2006 | 08:57 AM
why do i need to change the steering rack if on the hybrid racing site it doesnt say anything about it
Old Oct 3, 2006 | 09:19 AM
HARI.'s Avatar
So you can run the HASport EKK2 mount kit, as stated it centers the motor over the wheels better, better axle angle and better oil pan clearance
Old Oct 3, 2006 | 07:31 PM
thanx for the explanation i have one last question do you think its worth putting in a jdm rsx type r or should i just put in a k20a2
srnissanpower
14
Jun 30, 2007 09:43 PM
dcc183
EK Swaps
13
Jan 11, 2007 12:21 PM
blackj
Mar 23, 2006 11:22 AM
Friqui Tiqui
Apr 15, 2005 09:42 PM
the_reptilian
Jan 12, 2005 06:30 PM
