metal shavings in cylinder head
Old Jan 3, 2009 | 11:26 PM
cbaker1213's Avatar
Default metal shavings in cylinder head
I just had my head resurfaced, they took of .007 inches.
Now i have metal shavings in my cylinder head. how do i clean this out?
is a chemical bath the only way? i tried using my air compressor to blow it out but it wont come out.
I have shavings in the oil passages and coolant jacket, as well as a little bit around the valve passages (in the intake manifold).
Old Jan 4, 2009 | 12:02 AM
Uh, I would have thought they would clean that up at the shop...
Old Jan 4, 2009 | 01:51 PM
polo708's Avatar
they should have cleaned it for you like said. IMO you should have the entire thing pulled and cleaned if you do infact have metal shavings in your oil now. could be real bad down the road.
Old Jan 4, 2009 | 08:56 PM
riceburner700's Avatar
try and spray the whole head down with carb cleaner or brake cleaner and see if that helps, if it doesn't the head will need to be disassembled and cleaned
Old Jan 7, 2009 | 02:52 PM
S/C SI's Avatar
Back to the shop.
Old Jan 9, 2009 | 12:10 AM
cbaker1213's Avatar
thanks for the input. i didnt dare try to put the head back on before it was cleaned, so i have no shavings in my oil.
i'm going to have to find another shop to do the cleanup work, the first shop is giving me the run around. is cleaning typically included as part of the milling process? i guess its my fault for not asking about it before i had the work done... still i cant help but feel i'm being ripped off. i paid 55$ for a very minor milling job and got an unusably dirty part back.
Old Jan 9, 2009 | 08:48 AM
they will usually blow it off but any kind of heavy cleaning they will charge you extra for
Old Jan 9, 2009 | 12:37 PM
S/C SI's Avatar
Poor customer service. Do a proper and COMPLETE job.
Clean_Civic_98
Apr 9, 2011 03:22 PM
moplinger89
Jun 15, 2009 05:56 PM
pejaypreston
Dec 16, 2007 11:09 PM
KnightRiderCivic
12
Mar 8, 2007 03:41 AM
rit14623
Mar 2, 2006 02:26 PM
