Need Guidance
ORIGINAL: AgentofDarkness
Actually, if you get hasport mounts and those 400HP axles that could run you close to 950. But that would be overkill.
From hasport.com there about $400 alone. Also the axles that are only rated for 200 hp are about $300 so theres $700. And shipping will probably be $250-$350 so if I do it that way I will save enough money for shipping..lol.
do they say what condition the motor is ie. rebuilt/high mileage/low mileage, warranty etc? you only need to worry obout the block mainly, since your doing an almost entire rebuild on the head anyway, but it would really suck to spin a bearing or lobe a journal the first week out.
At jspecautosports.com they give you:
Mileage
Between 30 to 50 thousand miles. Click here for more information.
Warranty
60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine. We only ship engines with positive compression results. Click here for more information.
Mileage
Warranty
it seems to me your paying a little more for conveinience, which in my book is worth it sometimes, if you have a problem its all from the same place and they camnt say its because of a part you bought somewhere else... i would do it that way myself, but im sure alot of people might disagree.
