New and need some D15 help.
Old Mar 19, 2008 | 11:40 AM
Low 4 Door's Avatar
Default New and need some D15 help.
A few years back i bought a 1991 civic lx and now i am starting to have some problems with the engine. just recently the car feels like it is only running on 3 cylinders and so i checked the plugs and wires. come to find out that every plug and wire i took off the spark plug well in the valve cover was filled with oil. any one know how oil is getting there?
Also the car uses a quart of oil a week. i have heard this is typical with these motors with over 100000 miles.
thanks
Old Mar 23, 2008 | 05:57 PM
92CivicDude's Avatar
Default RE: New and need some D15 help.
I have an 92 civic and had the same problem i replaced the rubber seals around the plug holes and it fixed it
Old Mar 23, 2008 | 06:51 PM
riceburner700's Avatar
do a compression test or if you got alittle extra cash a leakdown test to find out were your oil usuage is going and how bad it is
Old Mar 23, 2008 | 07:08 PM
branx's Avatar
Member
i kno what it is for sure, ur gaskets btween the valve cover and head are leaking (the round ones), a quick fix is just buy some valve cover sealant and take of ur valve cover. where ever the gasket lies clean it with a rag or sumthing and put some sealnt, dont forget to do the small round ones around ur spark plugs because they r the ones that need help.
Old Mar 23, 2008 | 07:10 PM
Low 4 Door's Avatar
i put a valve cover gasket and timing belt on when i first got the car and put the new seals in. i mite buy a new gasket set and redo it and see what happens.
i am also gonna do the compression test. i am hoping hit up my local junkyard in the next few weeks for a motor and tranny.
Bsweet2010
Jul 9, 2010 10:45 PM
0slowpoke60
May 3, 2008 04:08 PM
spaz
Apr 27, 2008 10:16 PM
Shawkab
Oct 20, 2007 05:24 PM
Super Mario
Dec 4, 2005 09:05 AM
