overheating :-(
Old Sep 1, 2007 | 04:47 AM
StevieG1223's Avatar
Default overheating :-(
Hey, I have a 93 EX and it keeps overheating. I've replaced the water pump, thermostat, and radiator. The car seems to run fine for about an hour and then after that it's usually about half an hour of the temperture gage fluctuating followed by overheating. When it overheats the overflow is usually boiling. Any ideas?
Thanks,
Stephen
Old Sep 1, 2007 | 06:40 AM
WhiteBoyzRacing's Avatar
Default RE: overheating :-(
did you put the thermostat back in right? is the lower rad hose getting hot ? did you bleed the system? did you use new coolant and not reused the old stuff (wich you shud have used new coolant). i had the same problem but it was due to my turbo leaking the coolant.
Old Sep 1, 2007 | 02:30 PM
Cyphen's Avatar
my brother had this problem its realyl common the problem is your head is warped on one side and its building preasure into the radiator if you touch your radiator hose is rock hard correct? i just got the head re-surfaced on my brothers cars and threw that bitch back in there and its fine now
Old Sep 1, 2007 | 09:29 PM
expensive?
Old Sep 1, 2007 | 10:20 PM
Pete's Avatar
Decent amount of labor. You should take the head off and take it to a machine shop. Theyll tell ya if they can save it. If not, buy a used head online for like 150 and put a new headgasket on and bolt it up. Takes a long time if you dont know what youre doing......so paying labor for it is $.
Old Sep 2, 2007 | 06:37 AM
just buy a repairmanual for you car and read it , and just take your time doing the work, making sure you label everything, and dont re-use the headbolts. and if you have any friends that kno anything about cars see if they can help you out.
Old Sep 4, 2007 | 12:48 PM
Cyphen's Avatar
Not really that expensive but yeahmy brothers car still going alittle above half so i think his motor is ****ed so we are going to sell car.... it was fine for a couple days but it keeps over heating... sooo yeah... its not really hard to un-do the head just be carefull you have to undo valve covers,intake mani,exhaust mani, just little **** LOTS OF SCREWS dont loose any =-D make sure if you do it your self you clean the coolant out of the pistons before you let it sit
so none of it seeps in just take like a rag and soak it up to. to have head re-surfaced, your lookin at about $250-300 not only that if you have cracked valves its even more money! =-\ so yeah i dont know i hope this helped
Old Sep 5, 2007 | 07:39 AM
ksoma's Avatar
hehe funny thing is i had a very similar problem jus 2 days ago but it was due to the thermostat that needed replacing which was done today but get this: went to honda specialist garage to find out how much new thermostat and labour would cost and they quoted me £100 for it! can you believe that! jus to change the thermostat which was only a couple of bolts and all you had to do was make sure the thermostat was inserted properly...
Lucky friend was there to tell me that it was a simple job and all i had to do was buy the new thermostat and he showed me how to put it on. Now that i know this il make sure to do my research first before i go ahead and pay someone else to do the job, jus that you know the feeling when something goes wrong with your car you jus want it fixed as soon as possible without the car running into more problems and very anxious to get it done :P
Thankfully you guys are here to give a helping hand with advice and such and to be honest i would be lost without all of you here so i thank you all ^_^
Kojiro Soma
Old Sep 5, 2007 | 07:52 PM
Type RB's Avatar
Those 'just a couple of bolts' are a major PITA to get to, hence the high cost of labour.
Good on ya for learning how to do it yourself though.
trebor_2005
May 19, 2006 01:40 AM
Wooz
Apr 26, 2005 10:04 AM
9toes
Jan 28, 2005 01:43 PM
sonscivic
Jan 4, 2005 06:16 PM
Civic95Blue
Jul 29, 2004 10:09 PM
