poor/low idle when warm
Old Aug 4, 2008 | 03:05 PM
desert2007's Avatar
Default poor/low idle when warm
when my 96 civic is up to operating temperature, for some reason it wants to idle around 500 RPM's and sometimes just falls down like its gonna die and then shoots back up over 1k and then back down to around 750rpms. Its really weird im thinking maybe the MAF sensor or something. Its got a tenzo R intake, dc sport header, apexi catback.
any help would be appreciated.
Old Aug 4, 2008 | 03:32 PM
Is the CEL ON?
Some things that can cause a hunting idle problem:
-Dirty IAVC (see forum DIY section for cleaning instructions).
-Air trapped in the cooling system. Top off the coolant level in the radiator and bleed the system of air.
-An intake air or vacuum leak. Check hoses and connections leading to the intake manifold.
Old Aug 5, 2008 | 02:56 PM
desert2007's Avatar
i will check those things out. But the CEL has been on and off for the past year ive had it. But just within the last month or 2 the idle problem has come up.
Old Aug 5, 2008 | 03:43 PM
Vilex's Avatar
Could be the IACV, i'd go clean it.. Or, better yet. Go give your car a nice Seafoam treatment and see if that helps any. I'd also reccomend taking your car to autozone and see what codes are being pulled by the CEL, so you have a basic idea where to go from.
Old Aug 5, 2008 | 03:59 PM
+1
The CEL code can also be pulled at home (see link in my signature).
98civex
18
Apr 12, 2014 06:56 AM
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
rockaustin
Aug 24, 2008 06:52 AM
97_ex
Apr 18, 2007 09:29 PM
