pulley?
Old May 7, 2005 | 12:13 PM
tractorman12's Avatar
Default pulley?
ok, i just bought an underdrive pulley for my 92 and i went to instal it and i ran into some trouble. I put the pulley on the crank and torqued it down. i bought the belt it said to buy and i went to put it on. But the place for the belt on the pulley(the one closest to the engine) doesnt have the same diameter as the pulley for the alternator. But the 2nd spot for the pulley(the one closest to the wheel) has the same diamater as the alternator pulley. I know the pulley is on right. So my question is: Do i need a different pulley for the alternato since i bought an underdrive for the crank, or did they send me the wrong pulley?Or can i by a differnt belt with the same diameter of the crank pulley? If i do that will it fit on the alt. pulley??
sorry for the long post, thanks for any help
Old May 7, 2005 | 02:21 PM
Default RE: pulley?
i bought this one off ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=38656
Old May 7, 2005 | 10:45 PM
blackeyes's Avatar
Default RE: pulley?
i heard some bad stories with underdrive pullies and hondas so be careful.
Old May 8, 2005 | 01:51 AM
Pete's Avatar
Default RE: pulley?
im pretty sure the stock pullies are very heavy for a reason.......im pretty sure that anyone running any type of aftermarket audio system would wanna stay away from lightweight pullies......
Old May 8, 2005 | 08:22 AM
Default RE: pulley?
well i only spent 50 bucks on it so are you saying i should just forget about it and leave the old one on?
Old May 8, 2005 | 11:25 AM
Pete's Avatar
Default RE: pulley?
its ur decesion.........but if u plan on runnin any aftermarket audio equip......like an amp and subs i wouldnt use it.
Old May 8, 2005 | 01:58 PM
Kappa22's Avatar
Default RE: pulley?
Leave the old one on until you hit around 500 whp. Then it'll actually make a difference. The reason the stock one is so heavy is to balance the engine out top to bottom.
Karrde
12
Jan 24, 2009 05:09 AM
wimreems
Mar 19, 2005 10:09 PM
riceburner700
Feb 12, 2005 01:28 PM
02CivicEX
Feb 1, 2005 06:34 PM
NYC Civic
Jun 18, 2004 04:45 PM
